Calendar has been updated for 2018, check it out!
Moderator: 2bits
Postby 2bits » Mon Apr 30, 2018 8:11 pm
:beer: :stompspam: :pictures: :twisted:
Thomas
2bits
2bit Member
Images: 16
Re: Calendar has been updated for 2018, check it out!
Postby Sparksalot » Tue May 01, 2018 7:12 am
Where is it?
Done? Surely you jest. A teardrop is never "done".
Sparksalot
Images: 576
Postby 2bits » Tue May 01, 2018 8:37 am
It is in the top Announcements section of the South Central forum
Thomas
2bits
2bit Member
Images: 16
Postby Sparksalot » Tue May 01, 2018 9:28 am
I'm not seeing anything posted this year in that spot. :(
Sparksalot
Images: 576
Postby Staryder61 » Mon May 07, 2018 8:22 am
Not seeing the 2018 calendar either Thomas
Maybe post a link here, thanks
David
"A Great Mind is like a Parachute, it works best when it is open.."
"Our build Journal.." http://www.tnttt.com/viewtopic.php?f=50&t=69528
staryder61@gmail.com
Staryder61
Images: 325
Postby working on it » Mon May 07, 2018 10:16 am
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2220 lbs
156215157958148599
working on it
Images: 455
Postby Staryder61 » Mon May 07, 2018 10:31 am
working on it,
I saw this one, then saw where the last post for it was ( Postby 2bits ยป Mon Nov 03, 2014 8:21 pm ) so just figured it was an old one...
David
Staryder61
Images: 325
Postby 2bits » Thu May 17, 2018 11:11 pm
That's just when I first created that calendar thread, I have it pinned at the top in the announcements section and have been updating it throughout the years.
Thomas
2bits
2bit Member
Images: 16
Postby Staryder61 » Fri May 18, 2018 6:29 am
Thanks for the explanation Thomas, that helps...
David
Staryder61
Images: 325
Return to South Central
