The ROAM Camper Build
Moderator: Sonetpro
Re: The ROAM Camper Build
Postby titanpat57 » Mon Oct 12, 2015 7:06 pm
greygoos wrote:WOW I really liked your design and workmanship. I am in the process of designing my own camper and was wondering about the FRP. I read about the delaminating in the corners but was wondering on the overall condition of the panels at this time. Is there anything you might have done differently with the initial painting or upkeep. Thank you
Thank you very much for the compliments.
The FRP is holding up fine, I had aluminum bent for the problem corners, so they'll be fine.
The original process was lightly sand the panels, apply Rustloeum plastic white primer, and then applied Rustloeum Silver. It starting to show its age, so I'm going to try and coat it before winter.
My number one recommendation is to really think your seam locations through...or bite the bullet and get Filon to cover without any seams. This one will be for sale and the new one will be Filon for sure.
titanpat57
Images: 139
Postby irgod32 » Sat Jan 16, 2016 1:01 am
Beautiful build, what is the total trailer weight?
Tiny Trailer Builders of America
Build it and they will come
irgod32
Images: 55
Postby titanpat57 » Sat Jan 16, 2016 12:33 pm
irgod32 wrote:Beautiful build, what is the total trailer weight?
Thank you very much...it's been a fun build
I dropped a 150 lbs. or so getting rid of the big tent. This year I'm going to start shopping for a fishing kayak in the spring, so I'll throw that up on top. I think they weigh around 50-60 lbs. I'm going to run the same tires I put on the new truck, which are 275/70/17's BFG KO2's (including the spare underneath), and they run about 15 lbs more per tire. Another springtime upgrade will be new Trojan batteries...the original Interstate batteries are 6 years old now. The Trojans will probably double my existing amp/hours, but also add another 30 lbs.
All total I believe I'm at about 2500 lbs. loaded with water.
titanpat57
Images: 139
Postby Adirondackersouth » Tue Jan 26, 2016 6:05 am
titanpat57 wrote:Hi Everyone,
First off I'd like to say a special and heart felt thank you to all those who came before, took the time to document their ideas and builds, and spent countless hours and numerous talents fine tuning many of the methods applied in the creation of the ROAM. It is much apprecciated.
The ROAM (Recreation Optimized All-terrain Module) is my second attempt at a trailer build. The first was smaller, lighter, and lacked a brake axle....but was a really fun platform, so that's what I based this build off.
The project was started in mid April of 2010, and was taken out for the maiden voyage at the end of October the same year. The interior still needs some finish, as does the electrical system, but spring is right around the corner, and I'll be buying some wainscoating soon to pre-finish for the interior...but it been a welcomed break. There are already several early trips planned....I mean hell, how are going to work the bugs out?
The trailer started out its beginnings as a military generator platform, known as the M116A2, rated for 3/4 of a ton, or a total payload of 2750 pounds, which is what the finish weight will top out. The military axle was swapped out with a new Dexter, 3" dia. with brakes. I ordered 6 x 5.5 pattern, but my problem was that my Toyota 4Runner Trail has hub centric rims, not lug centric. In a quick synopsis, that translates into the wheel lines up with a "raised rim" that sticks out form the drum. In almost all cases your lug nuts center your wheel when tightend, but not in this case. That meant I had to buy a product called Spidertrax, that converts lug centric to hub centric. This build criteria was that the wheels on the trailer have to match the wheels on the tow vehicle.....I know, I know....it's not a news flash I have issues, so that said let the pictures begin
These are mostly the tongue modifications to accmodate the Max Coupler...an awesome multi-axis coupler...
I never did get real good at welding...but man I nailed the grinding part down...
First I want to say that you camper looks fantastic.
Second did you enjoy the process?
David Medici
Mechanicsville, Virginia 23116
Happy Trails
Adirondackersouth
Postby titanpat57 » Fri Jan 29, 2016 8:31 am
Thank you very much!
It was kinda like a marathon...not so much fun when running, but the joy of finishing last a long time. Pretty much all my spare time between April to October was spent in the back of the house working on it. The challenges of the welding are over, as I've done a lot since. The biggest hurdle is maintain the watertightness.....knowing what I know now I probably would've reconfigured the front differently..but that's what makes it unique. I always enjoy going out in it, and all systems still work great.
Another trailer is in development right now....there's a lot of satisfaction doing something with your own two hands....don't let fear or commonsense hold you back....go build something! :thumbsup:
titanpat57
Images: 139
Postby irgod32 » Sat Feb 13, 2016 9:08 pm
Great job!!! I agree with the previous comment
What did you use for skinning?
What does it weigh?
irgod32
Images: 55
Re: The ROAM Camper Build Refresh 2016
Postby titanpat57 » Tue May 31, 2016 10:18 am
Hello folks,
After the new 4runner purchase back in 11/15...it was time to do some upgrades to the camper.
Of course, matching wheels and rubber, somewhat matching paint, and another attempt at the front windows, this time using glass.
I carefully went over the roof, sides, vents, and anywhere else that could attract water or a leak. The Lexan I used for the front windows was just ok, but I was never happy with the look. I took the plexi out, took them to a glass shop, and had them duplicated in 1/8" glass. I then stopped at a tint shop and picked up a piece of 5% to tint the inside, as I found there was actually "too much" light coming in, especially in the early morning. It looks much better, and the tinted windows give it more matching look. I will eventually make a stone guard to protect the glass during travel time.
I decided to permanently mount the stove, I had done the sink earlier in the year. I just have to snap in the burner grills and slip on the knobs once I get to where I'm going. One small set back was the 5 gallon water can that fit on the stove side, had to be relocated to other side. I also permanently mounted the L5 water heater in a box to outside. I took a piece of stainless steel hinge and mounted a movable vented aluminum lid so the top of box stays pretty water tight.
I'm pretty much caught up for now. There was a trip planned to OEX http://www.overlandexperts.com/ for several days of driving training, but a schedule conflict caused us to cancel. I hope to make it out to various small weekend campouts, but summer is a very busy time at my job. Several planned trips are the MOAF just out side of State College, PA in August http://www.overlandfestival.com/, and the Vermont Overland Rally in Royalton, VT http://www.vermontoverland.com/vor/....hope to meet some old, and new, friends there.
As always..thanks for looking..have a safe and healthy summer....now some pictures.
titanpat57
Images: 139
Postby dales133 » Tue May 31, 2016 3:12 pm
Shes a beauty!
dales133
Postby 3GKnight » Tue May 31, 2016 5:00 pm
Sweet. Can you post a picture with the sink/counter down? Thanks!
3GKnight
Postby titanpat57 » Fri Jun 03, 2016 4:28 pm
dales133 wrote:Shes a beauty!
Thank you! :thumbsup:
titanpat57
Images: 139
Postby titanpat57 » Fri Jun 03, 2016 4:30 pm
3GKnight wrote:Sweet. Can you post a picture with the sink/counter down? Thanks!
There's 3-4 pictures on the previous page of the thread that show the kitchen down, and in use...thanks for looking
titanpat57
Images: 139
