The Coff-Inn
The Coff-Inn
Postby eLink » Sat May 18, 2019 3:05 pm
So I had this idea this morning...
Guaranteed to provide a peaceful rest!
eLink
eLink
Re: The Coff-Inn
Postby working on it » Sat May 18, 2019 4:05 pm
* There was a small, thin, coffin-like build a few years ago, by eggsalad that your idea reminded me of. He started his build thread out as a "one man sleeper" http://www.tnttt.com/viewtopic.php?f=50&t=57667&hilit=coffin#p1042865, but changed the thread to "the Coffin" http://www.tnttt.com/viewtopic.php?f=50&t=57667&hilit=coffin#p1042869.
* By the way, I initially was building my 4x8 for my wife, but she couldn't use it, due to claustrophobia. She called it "a coffin".
2013 HHRv "squareback/squaredrop", semi-offroad, 4x8 TTT, 2150 lbs
  • *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, & active-progressive bumpstop suspension
  • *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system modified for single-beam tongue
  • *100% LED's, GFCI outlets, 3x fans, AM/FM/C *A/C & heat, Optima AGM, inverter & charger(s)
  • *zinc/stainless front & side racks *98"L x 6" rooftop rod & reel carrier tube
156215157958148599
working on it
Images: 455
Re: The Coff-Inn
Postby eLink » Sat May 18, 2019 9:10 pm
I saw that thread, but it was hard to make out the coffin shape unless seen from above. This one, loosely based on Mikeschn's Weekender, would be more functional and the coffin shape is more obvious when placed on its side.
It's definitely meant to give a feeling of claustrophobia! I almost put a skylight on it, but decided that it probably wouldn't appeal to the undead demographic. The interior could be red satin button-tufted upholstery. :twisted:
eLink
eLink
Re: The Coff-Inn
Postby BigGoofyGuy » Sun Jun 02, 2019 9:27 pm
I did a Google on 'coff-in camper' and found this site.https://pbmotorcycletrailer.com/coffin-motorcycle-trailers/
BigGoofyGuy
Location: Hampton New Hampshire United States of America
