Re: Guess I’d better introduce myself over here...
pchast wrote:Question... Is there much fussing making the tape conform when going around the
curve and onto the perpendicular side. I notice no folds nor slitting.....
Thanks
Nope not really. My curves are a 24” radius, and it went on really smoothly. I attached the top side first and allowed the glue to set up a bit. I then coated both the surface and the back side of the tape. I spritzed the tape with water, and it relaxes it a lot. It also seems to begin to shrink up. I just slowly started working my way around the curve, keeping the puckers evenly spaced. Lots of little ones, not allowing for any large puckers. Keep working them out, and eventually they all laid flat and smooth with no lifting. Took about 1-2 minutes per curve.
I don’t know how tight of a radius one could tackle, but I’d guess maybe 16”?? With a heat gun and more spritzing...?
This is 3” wide tape, so narrower would fall somewhere between easier to bend, but more likely to lift. Lol.
