Tyvek
Finishes, paints and coatings
Tyvek
Postby wysedav » Tue Sep 10, 2019 8:15 am
Has anyone used used Tyvek under their Alumiumn skinned teardrop? Seems pretty easy and an extra layer of protection. I'd use a little 3M 77 to hold it in place on the wood, overlap the roof over the sides and seal with Tyvek tape.
just wondering if it seems worth it...I have the Tyvek on hand already.
Thanks,
David
wysedav
Re: Tyvek
Postby halfdome, Danny » Tue Sep 10, 2019 8:38 am
I don’t see the need for it and the spray adhesive might melt it.
I use Wilsonart contact cement on the plywood and scuffed aluminum,it gives a great bond that lasts.
:D Danny
halfdome, Danny
*Happy Camper
Images: 185
Re: Tyvek
Postby Aguyfromohio » Tue Sep 10, 2019 1:17 pm
Tyvek is entirely polyethylene, same as a milk jug, so it's probably unaffected by common solvents.
Aguyfromohio
Images: 68
Re: Tyvek
Postby RJ Howell » Tue Sep 10, 2019 1:49 pm
Okay, I have to ask... Why?
If your'e going to cover with aluminum, and it's wind and water tight... Again why?
I just see bonding issues for something not required. :thinking:
I love the curious mind though. :roll:
RJ Howell
Images: 34
Tyvek
Postby Greg M » Tue Sep 10, 2019 11:56 pm
Will Tyvek stick with glues? Polyethylene is pretty slippery when it comes to adhesives.
Greg M
*Geek Extraordinaire
Images: 85
Re: Tyvek
Postby Aguyfromohio » Wed Sep 11, 2019 8:02 am
Greg M wrote:Will Tyvek stick with glues? Polyethylene is pretty slippery when it comes to adhesives.
That is an excellent point.
In you can't glue to polyethylene or polypropylene with common adhesives, you need to use special adhesives or special techniques like flame treatment.
Aguyfromohio
Images: 68
Re: Tyvek
Postby RJ Howell » Wed Sep 11, 2019 10:10 am
According to the Tyvek website you can, but with water based. They also say to test first, so even they don't have a good answer. Most commercial use when glueing in hot glue, assuming sheets like doing veneer work.
I looked at this as a possible PMF. I just saw too many issues..
RJ Howell
Images: 34
Re: Tyvek
Postby tony.latham » Wed Sep 11, 2019 11:51 am
Just seal the cabin with polyurethane or epoxy before you sheath it and be done with it.
Both of those liquids soak into the wood, unlike a membrane ––which water could wick under.
T
Re: Tyvek
Postby wysedav » Wed Sep 11, 2019 3:25 pm
Ok, I was just thinking it would be a good secondary barrier. I don't think anything really needs to be bonded to it. It's just a floating skin like the aluminum. If the seal at a window or vent to the aluminum fails this would still be there to keep the water away from the wood.
Probably not necessary, I'm sure the sealants are much better than 20 years ago.
wysedav
Return to Skinning secrets
