Which bolt together trailer did you use?
Which bolt together trailer did you use on your build?
Harbor Freight 1195# 4x8 with 12" wheels
2
7%
Harbor Freight 1720# 4x8 with 12" wheels
17
57%
Northern Tool 4x8 with 12" wheels
0
No votes
Northern Tool 5x8 with 12" wheels
5
17%
Red Trailers 4x8 with 12" wheels
0
No votes
Red Trailers 5x8 with 12" wheels
1
3%
Not bolt together, custom fabricated trailer
4
13%
Other (please explain below)
1
3%
Total votes : 30
Postby mikeschn » Sun Dec 08, 2013 8:50 am
Updated Harbor Freight trailer Poll... We asked this question in 2004, when we were all kinda new at this... Thinking it's about time to get an update on which bolt together trailer you guys used...
So which bolt together trailer did you use?
Images: 479
Re: Which bolt together trailer did you use?
Postby working on it » Sun Dec 08, 2013 9:47 am
'A Cautionary Tale' Not a pre-packaged , bolt-together trailer, more like a custom built that keeps on growing! Like many others on this forum, I recycled a junk trailer that I had previously bought (for practically nothing), and let it sit and rot away for 17-18 years? in my backyard. I think I had $50 dollars tied up in it. Tried to give it away to friends and relatives several times, no takers. Then, I caught the TnTTT fever, and thought that I could build it up for about $500 or so, make it roadworthy, and get my wife out of her tent and onto a dry sleeping platform. Plan A. Plan B soon took over, though. With the help of my friend, who welds, I added structure and substance to the crappy trailer I had. (I think I spent at least $500 on steel and hardware alone; kept secret from the wife.) Overbuilt, and over equipped, compared to Plan A, the trailer is still being modified (and probably always will be), weight added or moved, and the axle-already with modifications for strength-( from the original tiny platform) will either be further beefed-up or replaced next (too much weight!). From this:
10/1/11, 8" tires, 50"x60" frame,twin bedspring size reference, 200lbs
to this
extra steel, now 4'x8' frame, hubs now 5x4.5,spacers, 14" tires
now this
modding: newer tonguebox, 1475lbs
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2220 lbs
156215157958148599
working on it
Images: 455
Postby Gage » Sun Dec 08, 2013 10:02 pm
I didn't use any 'Bolt Together' trailer frame. I planned on my teaardrop lasting 40- 50 years. And it will. It's already 13 years old. Has been to the East Coast twice and probably has close to 30,000 miles on it. How many of your 'Bolt Together' frame trailers can match that? :thinking:
Image Image Image
Gage
Images: 28
Postby jgrote » Mon Dec 09, 2013 12:06 am
I started with a H.F. 1195 trailer, and bolted it together like the instructions said. Then I ground off the paint in the 8 corners and welded them. Then I welded the front half to the back, both halves to the axle mounts, and then finally repainted (with H.F. bedliner). I repacked the bearings and am now calling it good enough. With discounts, sales, and frugal shopping, I think I have <$300 into getting my trailer ready to build on. I don't think I could have bought a trailer for that. I know that I may have to replace the axle at some point, but the trailer is well designed and it will be very easy to do in the future. I know that not everyone has access to a welder, but IMO it's the best tool I ever invested in. It has saved me thousands of dollars over the years in projects. I would not be afraid to build a trailer (and honestly it probably would have been faster), but I could not buy the steel, axle, tongue parts, wiring, axle, and wheels for anywhere near what I have into this one.
jgrote
Postby TPMcGinty » Mon Dec 09, 2013 8:15 am
My Northern Tools 5x8 was a prewelded angle iron trailer. I didn't vote since it isn't a bolt together at all.
Tim
TPMcGinty
Images: 146
Return to User Polls
