Mike's really, really easy hot sauce
Your recipes which you'd like to see in the T&TTT Cookbook #2.
Moderator: Mike B
Postby Mike B » Fri Jul 16, 2010 9:27 am
    chiles of your choice (mild to extremely hot), chopped up to make 1 cup
    2 mild yellow chiles, chopped
    2 or 3 cloves garlic, chopped
    vinegar
Put the chiles and the garlic in your food processor and process them until they are chopped fine and make a paste. Add enough vinegar to change the consistency from a paste to a sauce. Refrigerate.
I used Ancho chiles, which are very mild.
This goes very well on pork as a condiment, and also is very good on eggs at breakfast. It has replaced Tapatio hot sauce as my condiment of choice.
Update: A food processor really doesn't cut everything fine enough to make a sauce. Use a blender instead.
Mike
Hayden Lake, ID
Mike
Hayden Lake, ID
Mike B
Postby mikeschn » Thu May 05, 2011 7:49 pm
Hey Mike B,
You got a pic of this one?
Images: 479
Postby Mike B » Fri May 06, 2011 9:22 am
mikeschn wrote:You got a pic of this one?
It's hot sauce and it's green :D
I have kind of switched over to a recipe for red hot sauce:
8 red Chile peppers, unseeded and chopped
2-3 cloves garlic, chopped
vinegar
Put the peppers and the garlic in the food processor and pulse until chopped. Scrap down the sides of the processor and add a bit of vinegar. Turn on processor and add more vinegar while processing until the mixture is smooth enough for you and is not too thick. Refrigerate between uses.
I have to make more of this tonight, as I only have enough left for breakfast tomorrow morning. I will take a picture of it when I make it.
Please note that I am finishing up the 2nd edition of the T&TTT cookbook. It should be finished sometime this week. I will add the recipes that were posted this week to it. I am looking for a possible alternative cover picture.
Mike
Hayden Lake, ID
Mike
Hayden Lake, ID
Mike B
Postby mikeschn » Fri May 06, 2011 2:04 pm
I added a picture to the green bean and yellow split pea soup. Did you find that one?
Do you need any more recipes? How many are in cookbook #2?
Images: 479
Return to T&TTT Cookbook #2
